Audio Toolbox OSX 1.0.0
Post by Info-Mac » April 22nd, 2002, 9:00 am
Download: http://archive.info-mac.org/gst/snd/aud ... -100-x.hqx
File uploaded:
AudioToolboxOSX.sit
Program URL: http://www.blackcatsystems.com/software ... olbox.html
Author email: cps@blackcatsystems.com
Abstract:
Audio Toolbox is an audio function generator for the Macintosh. Using no
additional hardware, you can produce sine, square, triangle, and sawtooth
waveforms of any frequency up to 22 kHz, as well as generate noise.
Audio Toolbox can be used to create all sorts of cool sound effects. You
have full control over the frequency, type and volume of each sound
produced.
You can generate up two ten different waveforms. Each waveform can be
routed to either the left or right channel, or to both. The amplitude of
each waveform may be adjusted, as well as the volume on each channel, which
is a mix of any waveforms routed to that channel.
In addition, there is a sweep generator. Super for producing "Whoop Whoop"
sounds, sirens, and more.
Requires Mac OSX
Shareware: $20
